Hello, if you look at the attached image, you can see how the close points of my KML overlap each other.
Is there any way to automatically space them, based on the zoom? Thank you in advance.
https://cesiumjs.org/Cesium/Apps/Sandcastle/index.html?src=Clustering.html
I’m using this code.
The points have to be clear and spaced away from each other, not overlapped.
CesiumJS 1.60
Windows 7
Mozilla Firefox 68.0.2
