Switch 2D mode from 3D ,Label and Billboard Display Error。
Does this happen for you here?
I can’t seem to recreate this.
YES.
https://cesiumjs.org/Cesium/Build/Apps/Sandcastle/?src=Labels.html
and
https://cesiumjs.org/Cesium/Build/Apps/Sandcastle/?src=Billboards.html
**Switch 2D mode from 3D then Drag map ,**Label and Billboard Display Error。Changed a few computers still have this problem, use is the Google browser
在 2018年8月18日星期六 UTC+8上午1:20:40,Omar Shehata写道:
Is it related to the operating system? WIN7 use of Google Browser will have problems, but WIN10 under the use of Google Browser will not appear this problem.
It might be an issue with the driver. Make sure the drivers are up to date for your graphics card.
If that doesn’t fix it, can you post the results you get on Win 7 from: http://webglreport.com/
