Hello there, I love Cesium! If one day I have a baby, I will name her "Cesium". Long story short, here is the explanation:
Scenario says user should be able to see icons and the labels on icons together. (at least 6000). The icons are moving with 3 second intervals. FPS drops drastically.
Created example from "pointPrimitive" example@ cesium blog. Changed it to billboards because each feature should have its own icon. Here is the example:
in case of code cannot be seen, here is the sandcastle code:
var scene = viewer.scene;
scene.debugShowFramesPerSecond = true;
var numberOfPoints = 5000;
var gridSize = 360 / Math.sqrt(numberOfPoints);
var bbs = ;
var lbs = ;
var billboards = scene.primitives.add(new Cesium.BillboardCollection());
var labels = scene.primitives.add(new Cesium.LabelCollection());
for (var longitude = -180; longitude < 180; longitude += gridSize) {
for (var latitude = -90; latitude < 90; latitude += gridSize / 2) {
var bb = billboards.add({
imageId : 'billboard point',
image : '../images/Cesium_Logo_overlay.png',
position : Cesium.Cartesian3.fromDegrees(longitude, latitude),
var lb = labels.add({
text : longitude+"",
showBackground : true,
font : '14px monospace',
horizontalOrigin : Cesium.HorizontalOrigin.LEFT,
verticalOrigin : Cesium.VerticalOrigin.BOTTOM,
disableDepthTestDistance : Number.POSITIVE_INFINITY
bbs.push(bb);
lbs.push(lb);
function animate(){
for(var i = 0; i < bbs.length;i++){
var x = randomIntFromInterval(-180,180);
var y = randomIntFromInterval(-90,90);
var newPos = Cesium.Cartesian3.fromDegrees(x, y);
bbs[i].position = newPos;
lbs[i].position = newPos;
setTimeout(function(){
animate();
}, 3000);
function randomIntFromInterval(min,max){
return Math.random()*(max-min+1)+min;
animate();
Because planes are moving, not standing still, and each plane has a name to be seen.
Latest one. 1.56.1 I guess.
