While trying to code a basic imagery layer switcher (OpenStreetMap and BingAearial at the moment) layer 0 at North Pole shows up in front of the top layer (layer 1); switching layers (0 with 1) and moving closer to the pole it happens again (please see attached screenshots).
In Sandcastle:
HTML Tab:
JS Code Tab:
var osm = Cesium.createOpenStreetMapImageryProvider({
url : ‘https://a.tile.openstreetmap.org/’
imageryProvider : osm
var imageryLayers = viewer.imageryLayers;
var osmLayer = imageryLayers.get(0);
var bingAerialLayer = imageryLayers.addImageryProvider(Cesium.createWorldImagery());
imageryLayers.raiseToTop(bingAerialLayer);
Sandcastle.addToolbarMenu([{
text : ‘Bing Aerial’,
onselect : function() {
text : ‘OpenStreetMap’,
imageryLayers.raiseToTop(osmLayer);
}], ‘layerSwitcher’);
I have to code a basic map switcher (OSM and Bing for now). Is there a better way to accomplish that (the map switching) with Cesium without incurring in such an issue?
Cesium 1.50, Windows 7, Chrome Version 69.0.3497.100 (Official Build) (64-bit)
Thanks
