I’m using .czml files to view links between sensors and other objects in Local 8080 Sandcastle. I’ve tried numerous rgba combinations but the only colors that seem to work are blue, yellow and red.
I’ve converted hex colors from the Cesium website to rgba for several colors but the don’t work. Can you help?
I’m creating the ‘.czml’ file using python:
outFPtr.write( " “width”:4,\n")
outFPtr.write( " “material”:{\n")
outFPtr.write( " “solidColor”:{\n")
outFPtr.write( " “color”:{\n")
outFPtr.write( " “rgba”:[\n")
outFPtr.write( " 127,255,0,1\n")
This should be:
CHARTREUSE
Hex - #7FFF00
rgba(127, 255, 0, 1)
I need to use czml files in a local environment for stand alone capability. Using javascript is not an option in the short term.
Cesium v1.56
Windows 10
