We made the transparency effectt by using the property named fill-opacity in geojson file. When the Cesium property named “clampToGround” setted true on loading the geojson file ,transparency effectt can be seen in 3D mode. But it has no effect in 2D mode.
in 2D mode:
viewer.dataSources.add(Cesium.GeoJsonDataSource.load(‘transparent.geojson’, {
clampToGround:true
We have some geojson to show in 2D mode
Cesium JS 1.52 & Cesium JS 1.59
transparent.geojson (383 Bytes)
