I want to load Data from an URL. The URL points towards a python script which will get processed through mod_wsgi returning CZML complaint JSON.
Here is the JavaScript snippet:
var url = “http://geonode-dev.aes.hs-owl.de/py/writeCZML.py”;
var pySource = Cesium.CzmlDataSource.load(url);
viewer.dataSources.add(pySource);
Here is the Python script (http://geonode-dev.aes.hs-owl.de/py/writeCZML.py):
from czml import czml
def application(environ, start_response):
status = ‘200 OK’
output = createTestOutput()
response_headers = [('Content-type', 'text/json'),
('Content-Length', str(len(output)))]
start_response(status, response_headers)
return [output]
def createTestOutput():
# Create and append the document packet
doc = czml.CZML()
czmlBasePacket = czml.CZMLPacket(id=‘document’, version=‘1.0’)
doc.packets.append(czmlBasePacket)
# create packet
p = czml.CZMLPacket(id='point_test')
# init position object
pos = czml.Position()
# use coordinates
coords = [0, 52, 0]
# put coordinates into position objects coordinate list
pos.cartographicDegrees = coords
# create point object
point = czml.Point()
# add cord data to package
p.position = pos
point.color = {'rgba': [0, 255, 127, 55]}
point.pixelSize = 10
point.outlineWidth = 2
p.point = point
# add package to main czml document
doc.packets.append(p)
doc.dumps()
# responding as JSON
return doc.dumps()
This is the response I get via loading the python URL (http://geonode-dev.aes.hs-owl.de/py/writeCZML.py) through my browser:
"version": "1.0",
"id": "document"
"position": {
"cartographicDegrees": [
0.0,
52.0,
0.0
"id": "point_test",
"point": {
"color": {
"rgba": [
0,
255,
127,
55
"pixelSize": 10,
"outlineWidth": 2,
"show": false
I do not understand what prevents this to work. Any hints?
thanks,
Florian
