Manipulate and display in-memory rasters
Using the latest Cesium-1.62.
What is the best practice to manipulate and display in-memory client side rasters, as in the following scenario:
1. the client asks a service for some float32/paletted/RGB raster data (which the server will make specifically for that request)
2. the client needs to display the rasters on Cesium (with a given palette or as RGB image)
3. the client can manipulate the rasters (combining them in some way, for instance) and display the result on Cesium.
Methods I used but don’t give optimal results:
1. use WMS layers - these rasters which were produced as per the client request. if they need to be kept and serve in the server side that would be a problem.
2. calculate the pixel color and make a rectangle for each pixel - too slow for large rasters
**3. SingleTileImageryProvider - work for ****jpg, png, but **cannot display GeoTiff or other geospacial raster, and work only for RGB raster (and not with a given palette)
I read about gdal-js and loam, but I’m not sure if that could be helpful.
Please advise.
This sounds like an interesting application! What kind of project is this for?
There was a recent discussion on the forum about enabling something like this. There’s a feature request for it here: https://github.com/AnalyticalGraphicsInc/cesium/issues/8110. I think the easiest way to do this might be with post processing shaders, but OpenLayers does have a way of doing it on the CPU side as linked in the issue.
