Is there any possibility to enable mipmapping for image materials?
https://sandcastle.cesium.com/?src=Rectangle.html&label=Geometries
To have better visualization.
Latest version. Latest Chrome.
omar
2
Looks like there currently isn’t an option exposed to control this. I opened a feature request for this here: https://github.com/AnalyticalGraphicsInc/cesium/issues/8328
This is where the default sampler is defined. Changing this here would be the easiest way to test what it looks like with a mipmap filter if you have the CesiumJS source locally: https://github.com/AnalyticalGraphicsInc/cesium/blob/8e71f30e8937d59a5ea41d844d1ea9cc7c0655a1/Source/Renderer/Sampler.js#L18-L19
If you’re able to contribute exposing an option to control this as a pull request I’m sure that would be appreciated!
