if I “flyToBoundingSphere” with a pitch = -1.5707963267948966 (that I think should be view from top)
the camera look right, but the mouse doesn’t work anymore,
so no zoom, no pan, etc.
if I set the pitch to -1.55 it work a bit,
if I set the pitch to -1,52 it work again.
var pitch = -1.5707963267948966;
var offset = new Cesium.HeadingPitchRange(map.initHeading, pitch, 0);
viewer.camera.flyToBoundingSphere(boundingSphere, {
offset: offset,
1.66
