Ho do I insert Metadata in 3D Models (particularly text that describe objects of 3D Models)?
I need to publish 3D Models of Church's, Monument's, Envirnmental and describe it trought text or other infos (link to other documents, ...)
Cesium 1.4. Windows 10, Explorer and Chrome.
You could possibly create a czml file that includes names, descriptions, and other info alongside the links to model files.
Do you need to include metadata for sub-objects of the models?
Hi Sean
Thank you for your answer.
Do you have some example and tutorial to do that?
If subobjects is for example a object that I have inserted (like a emoticon for example) to make a link to other info, yes.
Best regards
There are a couple Sandcastle demos that you could check out:
The description property can contain html where you can place images, links, and other things that will show up in a window when the entity is clicked.
