I searched in the forum but did not found.
Can you tell me please what are the minimum hardware requirements for running cesium on a computer and what is your recommendation for an optimal user environment ?
thank you,
gil
thank you,
gil
The only real requirement is that your browser has WebGL support. If you see a spinning cube on this website, your browser supports WebGL: https://get.webgl.org/
Cesium will run faster on a computer with more processing power and a good video card, but it is not required.
Hannah
Hi Hannah,
I have an issue where I can see the rotating cube on clicking https://get.webgl.org/ however clicking "click to interact" yeilds a white screen.
What is the minimum webgl extensions requird.
Regards,
S B
What OS and browser are you experiencing this problem in?
Can you paste the results from http://webglreport.com/?
Hannah
