Moving map display from pilot perspective
Looking at using Cesium in a project where it simulates a vertical view from an aircraft. It wiil need to rotate around z-axis as airplane moves across map.
Are there Cesium APIs in place that make this do-able?
Is there an example you’d recommend?
Yes,
Their is not 1 single example currently in the Sandcastle, but if you look at the camera tutorial for how to disable user controls of the camera and the API document for the camera combined with the 3D Models you I think you will be able to get off to a good start.
