I am rendering a large Multipolygon from a GeoJson. The polygons render, but there are artifacts present. Sometime, the polygons overlap and extend out (see attached pictures).
I copied the same GeoJson in geojson.io and it looks fine. I also tried rendering them as individual polygons in cesium and they looked correct. So I don’t think the GeoJson has invalid points.
I just need to be able to shade the inside of a multiPolygon that I get from a server. I tried rendering them as individual polygons but that had other issues.
Cesium 1.50.0, Windows 10, Chrome
Thanks for the help
