Hi
I believe I have a working (at least semi-working) solution for Network Link Control Updates, and I’d like to see if the next step is really just to put up a PR up for it. However, without a deep understanding in the KML/Z DataSource code, I’m sure there’s stuff I’m missing. It’s done in a pretty simple way.
- There’s an object that holds a map (kml/z url → {kml, dataSource})
- Every time a kml/z comes in from a network link, it’s saved in the map
- If an Update tag is found, the
targetHref
is used to get the previously stored kml and data source - The kml is processed using the Change/Create/Delete tags and then loaded back into the data source
I haven’t seen a good way to
- do this without a global in the KmlDataSource file (to hold references to the kml/dataSources)
- remove the previously stored values when the kml is removed
I haven’t written tests yet since I’d like to see if the design is something that needs to change
