Continuing the discussion from A bug when rendering primitive with more than one geometry instance:
Nothing about the overlaps order,the shape of the overlap between polygon and polygon is obviously different in different camera perspective.When you are changing the camera orientation or position,you can see the shape of the overlap between polygon and polygon changing at the same time.
