Now polygon do not support callback,why? if that, how can do it? i
polygon: {
hierarchy: new Cesium.CallbackProperty(function(){ return m_obj.vertexList; }, false)
I think that should work if everything is set up correctly. Can you post a full code example on Sandcastle and share it here?
viewer.entities.add({
            polygon: {
                hierarchy: Cesium.Cartesian3.fromDegreesArray([121.77985082466147, 45.82755690534447,
                    121.92469306468644, 45.80741140225098, 121.90339453936461, 45.74846492085525,
                    121.81711483813052, 45.74476402445927, 121.67304724790127, 45.80900628113477,
                    121.56677650112483, 45.86267409629869
                material: Cesium.Color.RED
handler.setInputAction(function (e) {
            // 获取屏幕坐标
            let windowPosition = e.position;
            // 通过屏幕坐标获取当前位置的实体信息
            let pickedObject = viewer.scene.pick(windowPosition);
               console.log(pickedObject)
            // 如果实体信息存在则说明该位置存在实体
            if (Cesium.defined(pickedObject)) {
                // 获取当前点的实体
                let entity = pickedObject.id;
                // 如果实体为面同时没有处于编辑状态,那么保存面的实体
                if (entity.name === "polygon" && !isEditable) {
                    entityObj = entity;
                    // 生成编辑点
                    for (let cartesian of entityObj.polygon.hierarchy._value.positions) {
                        let point = viewer.entities.add({
                            position: cartesian,
                            point: {
                                color: Cesium.Color.WHITE,
                                pixelSize: 8,
                                outlineColor: Cesium.Color.BLACK,
                                outlineWidth: 1
                        // 保存点的ID以便删除
                        pointsId.push(point.id);
                    // 设置编辑状态为true
                    isEditable = true;
                    // 禁止地球旋转和缩放,地球的旋转会对鼠标移动监听有影响,所以需要禁止
                    viewer.scene.screenSpaceCameraController.enableRotate = false;
                    viewer.scene.screenSpaceCameraController.enableZoom = false;
                } else if (entity.name === "gon_point") {
                    // 如果实体为编辑点,那么设置当前编辑点为该点
                    currentPoint = entity;
        }, Cesium.ScreenSpaceEventType.LEFT_DOWN)
        handler.setInputAction((event) => {
            if (isEditable && currentPoint) {
                let windowPosition = event.startPosition;
                let ellipsoid = viewer.scene.globe.ellipsoid;
                let cartesian = viewer.camera.pickEllipsoid(windowPosition, ellipsoid);
                if (!cartesian) {
                    return;
                currentPoint.position = cartesian;
                let points = [];
                for (let id of pointsId) {
                    points.push(viewer.entities.getById(id).position._value);
                entityObj.polygon.hierarchy = new Cesium.CallbackProperty(() => {
                    return points;
                }, false);
polygon use a callback to report an error as follows:
TypeError: Cannot read property ‘length’ of undefined
I’m having trouble running your example - I think the code you posted is missing some sections (like “isEditable” is not defined). Can you share a direct link to your code example like the instructions here explain: How to share custom Sandcastle examples ?
var positionList =
  var firstClick = true;
  var pos={positions:null};
  var handler = new Cesium.ScreenSpaceEventHandler(viewer.scene.canvas);
       var position = viewer.scene.pickPosition(e.position)
      var cartographic = new Cesium.Cartographic.fromCartesian(position);
      var lon = Cesium.Math.toDegrees(cartographic.longitude)
      var lat = Cesium.Math.toDegrees(cartographic.latitude)
      var height = cartographic.height;
      positionList.push(lon)
      positionList.push(lat)
    if (firstClick) {
      pos.positions=Cesium.Cartesian3.fromDegreesArray(positionList);
        show: true,
        polygon: {
          hierarchy: new Cesium.CallbackProperty(function () {
            return pos.positions;
          }, false),
          //extrudedHeight:5000,
          material: Cesium.Color.YELLOW.withAlpha(0.8),
      firstClick=false;
    }else{
    console.log(position)
  }, Cesium.ScreenSpaceEventType.LEFT_CLICK)
  handler.setInputAction(function(e){
      handler.removeInputAction(Cesium.ScreenSpaceEventType.LEFT_CLICK)
  },Cesium.ScreenSpaceEventType.RIGHT_CLICK)
  • Please try this code
the error is this:
PolygonGeometry.createGeometry = function (polygonGeometry) {
var vertexFormat = polygonGeometry._vertexFormat;
var ellipsoid = polygonGeometry._ellipsoid;
var granularity = polygonGeometry._granularity;
var stRotation = polygonGeometry._stRotation;
var polygonHierarchy = polygonGeometry._polygonHierarchy;
var perPositionHeight = polygonGeometry._perPositionHeight;
var closeTop = polygonGeometry._closeTop;
var closeBottom = polygonGeometry._closeBottom;
var arcType = polygonGeometry._arcType;
var outerPositions = polygonHierarchy.positions; // this undefined
thank you for your help
