I want to draw polygon dynamicly, The code below works fine when i don`t add terrain. But when terrain is added, it sometimes throws error:
DeveloperError: normalized result is not a number
Error
at new DeveloperError (/Cesium/Source/Core/DeveloperError.js:43:19)
at Function.Cartesian3.normalize (/Cesium/Source/Core/Cartesian3.js:420:19)
at computeAttributes (/Cesium/Source/Core/PolygonGeometry.js:218:53)
at Function.PolygonGeometry.createGeometry (/Cesium/Source/Core/PolygonGeometry.js:856:37)
at loadSynchronous (/Cesium/Source/Scene/Primitive.js:1203:56)
at Primitive.update (/Cesium/Source/Scene/Primitive.js:1771:17)
at ClassificationPrimitive.update (/Cesium/Source/Scene/ClassificationPrimitive.js:935:25)
at GroundPrimitive.update (/Cesium/Source/Scene/GroundPrimitive.js:789:25)
at PrimitiveCollection.update (/Cesium/Source/Scene/PrimitiveCollection.js:365:27)
I found that the error occurs when I clicked the map on the same location twice sequencely, the error occurs. And one strange thing is that if i don`t assign callbackproperty to the polygon`s position but a cartesian3 array which the array`s element is the same to the callbackproperty`s dynamic array element, it work fines.
terrainProvider: Cesium.createWorldTerrain()
var PolygonCreator = function (viewer) {
this.viewer = viewer;
this.drawingVertexes = ;
this.drawingPolygonCreated = false;
this.callbackProperty = undefined;
this.onLeftClickHandler = this.onLeftClickHandler.bind(this);
this.onRightClickHandler = this.onRightClickHandler.bind(this);
this.onMouseMoveHandler = this.onMouseMoveHandler.bind(this);
this.bindEvent();
PolygonCreator.prototype = {
constructor: PolygonCreator,
bindEvent() {
this.eventHandler = new Cesium.ScreenSpaceEventHandler(this.viewer.canvas);
this.eventHandler.setInputAction(this.onLeftClickHandler, Cesium.ScreenSpaceEventType.LEFT_CLICK);
this.eventHandler.setInputAction(this.onRightClickHandler, Cesium.ScreenSpaceEventType.RIGHT_CLICK);
this.eventHandler.setInputAction(this.onMouseMoveHandler, Cesium.ScreenSpaceEventType.MOUSE_MOVE);
onLeftClickHandler(event) {
var point = this.getEarthPoint(event.position, this.mode);
this.drawingVertexes.push(point);
if (this.drawingVertexes.length == 2 && !this.drawingPolygonCreated) {
this.callbackProperty = new Cesium.CallbackProperty(function () {
return this.drawingVertexes;
}.bind(this), false);
this.addPolygon(this.callbackProperty)
this.drawingPolygonCreated = true;
this.addVertex(point);
onRightClickHandler(event) {
onMouseMoveHandler(event) {
var point = this.getEarthPoint(event.endPosition, this.mode);
var drawingVertexes = this.drawingVertexes;
if (drawingVertexes.length == 2) {
} else if (drawingVertexes.length > 2) {
drawingVertexes.pop();
point.y += (1 + Math.random());
point.x += (1 + Math.random());
point.z += (1 + Math.random());
getEarthPoint(position, mode) {
var point = null;
var ray = this.viewer.camera.getPickRay(position);
point = this.viewer.scene.globe.pick(ray, this.viewer.scene);
return point;
addVertex(point) {
var entity = new Cesium.Entity({
position: point,
point: {
color: Cesium.Color.WHITE,
pixelSize: 10,
outlineColor: Cesium.Color.BLACK,
outlineWidth: 1,
heightReference: Cesium.HeightReference.CLAMP_TO_GROUND,
this.viewer.entities.add(entity);
addPolygon(position) {
polygon: {
hierarchy: position,
outline: true,
material: new Cesium.ColorMaterialProperty(Cesium.Color.WHITE.withAlpha(0.7)),
new PolygonCreator(viewer);
I want to draw polygon dynamic. When mouse move ,the polygon is drawing dynamicly.
Cesium1.43, windows 10, Chrome
