npm install ENOTFOUND error
Hi All,
When i try to set up and run the Cesium earth, i got a error as shown below
While trying to execute the command npm install in the cesium root directory i get the following
C:\GIS\webgl>npm install
npm ERR! Windows_NT 6.3.9600
npm ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\
node_modules\\npm\\bin\\npm-cli.js" "install"
npm ERR! node v4.3.2
npm ERR! npm v2.14.12
npm ERR! code ENOTFOUND
npm ERR! errno ENOTFOUND
npm ERR! syscall getaddrinfo
npm ERR! network getaddrinfo ENOTFOUND registry.npmjs.org registry.npmjs.org:443
npm ERR! network This is most likely not a problem with npm itself
npm ERR! network and is related to network connectivity.
npm ERR! network In most cases you are behind a proxy or have bad network settin
gs.
npm ERR! network
npm ERR! network If you are behind a proxy, please make sure that the
npm ERR! network 'proxy' config is set properly. See: 'npm help config'
npm ERR! Please include the following file with any support request:
npm ERR! C:\GIS\webgl\npm-debug.log
The content of the npm-debug.log file is shown below
0 info it worked if it ends with ok
1 verbose cli [ 'C:\\Program Files\\nodejs\\node.exe',
1 verbose cli 'C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js',
1 verbose cli 'install' ]
2 info using npm@2.14.12
3 info using node@v4.3.2
4 verbose readDependencies loading dependencies from C:\GIS\webgl\package.json
5 verbose install where, deps [ 'C:\\GIS\\webgl',
5 verbose install [ 'jsdoc', 'express', 'compression', 'request', 'yargs' ] ]
6 verbose install where, peers [ 'C:\\GIS\\webgl', ]
7 verbose installManyTop reading for lifecycle C:\GIS\webgl\package.json
8 info preinstall cesium@0.30.0
9 verbose readDependencies loading dependencies from C:\GIS\webgl\package.json
10 silly cache add args [ 'jsdoc@3.3.0-alpha9', null ]
11 verbose cache add spec jsdoc@3.3.0-alpha9
12 silly cache add args [ 'express@4.4.4', null ]
13 verbose cache add spec express@4.4.4
14 silly cache add parsed spec Result {
14 silly cache add raw: 'jsdoc@3.3.0-alpha9',
14 silly cache add scope: null,
14 silly cache add name: 'jsdoc',
14 silly cache add rawSpec: '3.3.0-alpha9',
14 silly cache add spec: '3.3.0-alpha9',
14 silly cache add type: 'version' }
15 silly addNamed jsdoc@3.3.0-alpha9
16 verbose addNamed "3.3.0-alpha9" is a plain semver version for jsdoc
17 silly mapToRegistry name jsdoc
18 silly mapToRegistry using default registry
19 silly mapToRegistry registry https://registry.npmjs.org/
20 silly mapToRegistry uri https://registry.npmjs.org/jsdoc
21 verbose addNameVersion registry:https://registry.npmjs.org/jsdoc not in flight; fetching
22 silly cache add parsed spec Result {
22 silly cache add raw: 'express@4.4.4',
22 silly cache add scope: null,
22 silly cache add name: 'express',
22 silly cache add rawSpec: '4.4.4',
22 silly cache add spec: '4.4.4',
22 silly cache add type: 'version' }
23 silly addNamed express@4.4.4
24 verbose addNamed "4.4.4" is a plain semver version for express
25 silly mapToRegistry name express
26 silly mapToRegistry using default registry
27 silly mapToRegistry registry https://registry.npmjs.org/
28 silly mapToRegistry uri https://registry.npmjs.org/express
29 verbose addNameVersion registry:https://registry.npmjs.org/express not in flight; fetching
30 silly cache add args [ 'compression@1.0.8', null ]
31 verbose cache add spec compression@1.0.8
32 silly cache add parsed spec Result {
32 silly cache add raw: 'compression@1.0.8',
32 silly cache add scope: null,
32 silly cache add name: 'compression',
32 silly cache add rawSpec: '1.0.8',
32 silly cache add spec: '1.0.8',
32 silly cache add type: 'version' }
33 silly addNamed compression@1.0.8
34 verbose addNamed "1.0.8" is a plain semver version for compression
35 silly mapToRegistry name compression
36 silly mapToRegistry using default registry
37 silly mapToRegistry registry https://registry.npmjs.org/
38 silly mapToRegistry uri https://registry.npmjs.org/compression
39 verbose addNameVersion registry:https://registry.npmjs.org/compression not in flight; fetching
40 silly cache add args [ 'request@2.36.0', null ]
41 verbose cache add spec request@2.36.0
42 silly cache add parsed spec Result {
42 silly cache add raw: 'request@2.36.0',
42 silly cache add scope: null,
42 silly cache add name: 'request',
42 silly cache add rawSpec: '2.36.0',
42 silly cache add spec: '2.36.0',
42 silly cache add type: 'version' }
43 silly addNamed request@2.36.0
44 verbose addNamed "2.36.0" is a plain semver version for request
45 silly mapToRegistry name request
46 silly mapToRegistry using default registry
47 silly mapToRegistry registry https://registry.npmjs.org/
48 silly mapToRegistry uri https://registry.npmjs.org/request
49 verbose addNameVersion registry:https://registry.npmjs.org/request not in flight; fetching
50 silly cache add args [ 'yargs@1.2.6', null ]
51 verbose cache add spec yargs@1.2.6
52 silly cache add parsed spec Result {
52 silly cache add raw: 'yargs@1.2.6',
52 silly cache add scope: null,
52 silly cache add name: 'yargs',
52 silly cache add rawSpec: '1.2.6',
52 silly cache add spec: '1.2.6',
52 silly cache add type: 'version' }
53 silly addNamed yargs@1.2.6
54 verbose addNamed "1.2.6" is a plain semver version for yargs
55 silly mapToRegistry name yargs
56 silly mapToRegistry using default registry
57 silly mapToRegistry registry https://registry.npmjs.org/
58 silly mapToRegistry uri https://registry.npmjs.org/yargs
59 verbose addNameVersion registry:https://registry.npmjs.org/yargs not in flight; fetching
60 verbose request uri https://registry.npmjs.org/jsdoc
61 verbose request no auth needed
62 info attempt registry request try #1 at 10:53:02 AM
63 verbose request id 0e1999c03252b85d
64 http request GET https://registry.npmjs.org/jsdoc
65 verbose request uri https://registry.npmjs.org/express
66 verbose request no auth needed
67 info attempt registry request try #1 at 10:53:02 AM
68 http request GET https://registry.npmjs.org/express
69 verbose request uri https://registry.npmjs.org/compression
70 verbose request no auth needed
71 info attempt registry request try #1 at 10:53:02 AM
72 http request GET https://registry.npmjs.org/compression
73 verbose request uri https://registry.npmjs.org/request
74 verbose request no auth needed
75 info attempt registry request try #1 at 10:53:02 AM
76 http request GET https://registry.npmjs.org/request
77 verbose request uri https://registry.npmjs.org/yargs
78 verbose request no auth needed
79 info attempt registry request try #1 at 10:53:02 AM
80 http request GET https://registry.npmjs.org/yargs
81 info retry will retry, error on last attempt: Error: getaddrinfo ENOTFOUND registry.npmjs.org registry.npmjs.org:443
82 info retry will retry, error on last attempt: Error: getaddrinfo ENOTFOUND registry.npmjs.org registry.npmjs.org:443
83 info retry will retry, error on last attempt: Error: getaddrinfo ENOTFOUND registry.npmjs.org registry.npmjs.org:443
84 info retry will retry, error on last attempt: Error: getaddrinfo ENOTFOUND registry.npmjs.org registry.npmjs.org:443
85 info retry will retry, error on last attempt: Error: getaddrinfo ENOTFOUND registry.npmjs.org registry.npmjs.org:443
86 info attempt registry request try #2 at 10:53:12 AM
87 http request GET https://registry.npmjs.org/jsdoc
88 info attempt registry request try #2 at 10:53:12 AM
89 http request GET https://registry.npmjs.org/express
90 info attempt registry request try #2 at 10:53:12 AM
91 http request GET https://registry.npmjs.org/compression
92 info attempt registry request try #2 at 10:53:12 AM
93 http request GET https://registry.npmjs.org/request
94 info attempt registry request try #2 at 10:53:12 AM
95 http request GET https://registry.npmjs.org/yargs
96 info retry will retry, error on last attempt: Error: getaddrinfo ENOTFOUND registry.npmjs.org registry.npmjs.org:443
97 info retry will retry, error on last attempt: Error: getaddrinfo ENOTFOUND registry.npmjs.org registry.npmjs.org:443
98 info retry will retry, error on last attempt: Error: getaddrinfo ENOTFOUND registry.npmjs.org registry.npmjs.org:443
99 info retry will retry, error on last attempt: Error: getaddrinfo ENOTFOUND registry.npmjs.org registry.npmjs.org:443
100 info retry will retry, error on last attempt: Error: getaddrinfo ENOTFOUND registry.npmjs.org registry.npmjs.org:443
101 info attempt registry request try #3 at 10:54:12 AM
102 http request GET https://registry.npmjs.org/jsdoc
103 info attempt registry request try #3 at 10:54:12 AM
104 http request GET https://registry.npmjs.org/express
105 info attempt registry request try #3 at 10:54:12 AM
106 http request GET https://registry.npmjs.org/compression
107 info attempt registry request try #3 at 10:54:12 AM
108 http request GET https://registry.npmjs.org/request
109 info attempt registry request try #3 at 10:54:12 AM
110 http request GET https://registry.npmjs.org/yargs
111 verbose stack Error: getaddrinfo ENOTFOUND registry.npmjs.org registry.npmjs.org:443
111 verbose stack at errnoException (dns.js:26:10)
111 verbose stack at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:77:26)
112 verbose cwd C:\GIS\webgl
113 error Windows_NT 6.3.9600
114 error argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install"
115 error node v4.3.2
116 error npm v2.14.12
117 error code ENOTFOUND
118 error errno ENOTFOUND
119 error syscall getaddrinfo
120 error network getaddrinfo ENOTFOUND registry.npmjs.org registry.npmjs.org:443
120 error network This is most likely not a problem with npm itself
120 error network and is related to network connectivity.
120 error network In most cases you are behind a proxy or have bad network settings.
120 error network
120 error network If you are behind a proxy, please make sure that the
120 error network 'proxy' config is set properly. See: 'npm help config'
121 verbose exit [ 1, true ]
Please help to resolve the issue
