My aim is to publish the data in cityGML format to web. After some research in internet I understand that dumping the data to the PostGIS database and then convert the data into tiles,JSON using "3D City Database Importer/Exporter" tool. By using sample given in 3DCityDB-Web-Map-Client zip file,just I changed the path of the files. The data is rendered but it disappear suddenly. Could you please help me to solve this issue?
