On Prem Asset Server with TLS
Is it possible to configure TLS when setting up or running the Asset Server?
Hi Adam,
The asset server that ships with the 3D Tiling Pipeline is meant to live behind a reverse proxy, like nginx, or CDN, like CloudFront and does not have direct support for enabling TLS.
If you aren’t aware, we recently released Cesium ion Self-Hosted, which includes the tiling pipeline as well as the Cesium ion UI, REST API, and an all knew asset server. You can read about it in the blog announcement.
