Is there any way to create a url pointing at the cesium viewer with a kml file link that will open automatically?
Something like
https://dl.dropboxusercontent.com/u/73681667/TheWarden/VIC/AWSNew/FWIChangeLive.kml Open = http://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/index.html
Can’t find a way to embed the viewer in to Google Sites so just want to use a link for now.
Thanks
Derek
I did this on my python Flask server using jinja 2 templating. I just pass the reference to the kml file as KMLFILE as a KmlDatSource.:
{% if KMLFILE %}
viewer.dataSources.add(Cesium.KmlDataSource.load(’{{KMLFILE}}’,options));
{% endif %}
Thanks Jesse but can’t host my own server for this one so just after a simple url solution
D
I don’t see the problem then. You should be able to add a KML Data Source using:
D
{% if KMLFILE %}
viewer.dataSources.add(Cesium.KmlDataSource.load(‘{{KMLFILE}}’,options));
{% endif %}
Something like
Thanks
Derek
viewer.dataSources.add(Cesium.KmlDataSource.load(‘url’,options));
Mmm not sure if I have explained properly Jesse. This is what I am doing manually, but I just want to be able to do it with a single url I can send to someone to click on.
I currently click on this link to open the Cesium Viewer in Google Chrome
Then I drag and drop this .kml file into the viewer which displays it.
I would like to to be able to insert the kml link into the URL as an argument
http://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/index.html https://dl.dropboxusercontent.com/u/73681667/TheWarden/VIC/AWSNew/FWIChangeLive.kml
I have zero web development experience so have to keep it simple.
Thanks
Derek
CesiumViewer looks for a “source” query parameter and loads that automatically.
So …CesiumViewer/index.html?source=whatever
List of query parameter options is in the source:
https://github.com/AnalyticalGraphicsInc/cesium/blob/master/Apps/CesiumViewer/CesiumViewer.js#L33
Fantastic, just what I was looking for.
Thanks heaps Scott
