Volker
#1
Hi!
I’m trying to open a kml file with gx:track, i use the bikeRide.kml sample but it doesn’t appear on the window.
I tried to import the cesium sandcastle load kml exemple on html but it doesen’t work. I don’t know what to do now.
omar
#2
I would check to see if there are any errors in the browser console. It may be unable to find the KML file.
Are you opening the HTML file just by double clicking it, or do you have a local server running?
Volker
#3
i forgot to mention that. There is no error on the console, the path is correct and i’am hosting a local server to open the file.
omar
#4
Why do you have a “viewer.dataSources.removeAll();” line in there? It’s possible it’s adding it and immediately removing it from the scene.
