I find that when I apply an orientation to an entity, the 3D model is rotated around a point which is not the origin of the 3D model.
I modded the 3D Model sandcastle example to rotate the aircraft model around the roll axis. Here you can see that the aircraft is rolling around a point above the wings. However, the origin of the model is below the wing; so it is not rotating around the origin.
If you upload the Cesium_Air.glb here, and activate the RenderGrid, you can see that the model origin is below the wing.
https://sandbox.babylonjs.com/
Creating a flight simulation; need the model to rotate around its center of gravity.
Latest as of today, Chrome browser.
Thanks!
