When I load multiple GeoJSON vector layers, each of 23 MB size, the webapp hangs and throws out OutOfMemory error.
//Load data - From toposheets
Cesium.GeoJsonDataSource.clampToGround = true;
var dataSource = Cesium.GeoJsonDataSource.load(’…/GeoJSON/Topo1.geojson’);
var dataSource2 = Cesium.GeoJsonDataSource.load(’…/GeoJSON/Topo2.geojson’);
viewer.dataSources.add(dataSource2);
I want to load multiple Point/Polygon vector layers
1.42
