I want to implement pan control using right mouse button. How could this be achieved?
Can I simply trigger Left mouse up down in my right mouse up down?
I think you’ll have to turn off the default controls and set your own, like I described here:
https://groups.google.com/d/msg/cesium-dev/fPbgK9_TMt0/zS8dmzA1AgAJ
I’m not sure if there’s an easier way to do this. What sort of application are you building that requires this? Is this more of a preference thing?
You could probably dig into the source code and switch those two events (here’s the file where they’re initialized https://github.com/AnalyticalGraphicsInc/cesium/blob/master/Source/Core/ScreenSpaceEventHandler.js) but that involves creating your own modified version of the Cesium source.
I actually want to use one mouse button for pan (which is there for left mouse button by default), and other mouse button to rotate around clicked entity.
I can rotate around using left mouse button with simply this line of code: viewer.camera.lookAt(pickedCenter);
But then I want pan using right mouse button. So I was thinking to trigger/simulate left mouse up/down event using right mouse up/down.
handler.setInputAction(function(movement) {
// Pick a new feature
var pickedFeature = viewer.scene.pick(movement.position);
if (!Cesium.defined(pickedFeature) || typeof(pickedFeature.content) == ‘undefined’) {
return;
scene.screenSpaceCameraController.enableRotate = true;
var x = pickedFeature.content._model._rtcCenter3D.x;
var y = pickedFeature.content._model._rtcCenter3D.y;
var z = pickedFeature.content._model._rtcCenter3D.z;
pickedCenter = Cesium.Cartesian3.fromElements(x, y, z);
}, Cesium.ScreenSpaceEventType.LEFT_DOWN);
