when panning at a small scale, ie globe, country, region level, the point you pick with the mouse stays more or less below the mouse during the pan providing a good uX to the user as globe/terrain movement is more or less identical as the mouse/cursor movement, ie coherent.
In case you are at a very large scale, say for example zoom level 17-18, when panning, the globe/terrain moves faster than the mouse cursor, making it difficult for the user to do short panning movement, that are requirement for example if you’d like to pan along a walking path in the mountain at zoom level 17-18.
Is an adjustment of the pan speed or pan movement per zoom level planned? Is this part of the issue https://github.com/AnalyticalGraphicsInc/cesium/pull/1817?
Best regards
Emmanuel
