Hi, I am using SampledPositionProperty to create an animated path from tracking (GPS) data and using cesium 1.114 within a vue.js based application.
First, I tested with the czml sandcastle example of drone flight and experienced the same behaviour with the path not animating correctly.
var pathEntity = entities.add({
availability: new Cesium.TimeIntervalCollection([ new Cesium.TimeInterval({ start: startTime, stop: stopTime }) ]),
position: positionProperty,
path:{
width: 2,
resolution : 1,
leadTime: 5,
trailTime: 50,
color: Cesium.Color.RED,
point: { pixelSize: 15, color: Cesium.Color.YELLOW },
Seems simple code but the behaviour is not as expected. The point (yellow dot) animated correctly, and the blue polyline draws correctly, just the path in animation (dragging/playing) is incorrect.
Any help is appreciated, thanks.
