I’ve been working on a project that displays time-dependent 2D weather areas on the globe, with some additional text and an icon, for one day. That means I am basically loading 3000 polygons from a backend service, parsing them, and adding them to the globe as entities containing a PolygonGraphic, a BillboardGraphic, a PolylineGraphic (to draw a thick outline since polygon outlineWidth > 1 is not supported), a LabelGraphic and an availability TimeInterval to show them only when they are active. Everything is working great so far when I move the timeslider, the only problem is the performance hit I get after adding the 3000 polygons/billboards/labels, which takes my FPS from constant 60 to about 23 at best, even when I let cesium sit and load for a while to make sure it is done processing in the background.
It looks like this:
Do you guys have any recommendations to improve performance for this scenario?
Would migrating to the Primitive API help?
Is 3DTiles Streaming an option here?
Are polygons that are not displayed because of their availibillity still affecting performance?
I already searched the forums for similar questions, and the closest I have found is this:
It seems to be unanswered, but I have read in another post that polylines are sometimes the problem
Thanks @Gu-Miao and @Alexander_Johannesen for your suggestions, I will look into it, already done an experimental sandcastle and the performance looks way better.
Another question, if I use the Primitive API for this, I will lose the comfort of having an Entity Availability TimeInterval (and properties in general) to display the polygon only on their active times. Does anybody have a handy solution/idea for this? Otherwise I’ll have to roll my own implementation
