In Cesium 1.36,I want to draw a polyline on 3dtiles,pickPosition does not work.I must set depthTestAgainstTerrain = true,this setting is not required in previous versions
if I set depthTestAgainstTerrain = true, label will be covered by the ground.
how to solve this problem?
1.36,Win10,Chrome
