What can be the equivalent method in Cesium as supposed to placemark.setDescription in Google Earth API? Label only renders single line as String. But what about multi-line comments/description about a location? Or is there a way to render html content in a placemark?
You can use the description property to have content appear in the InfoBox widget when you click the placemark. This can be plain text or html. Here is an example:
var viewer = new Cesium.Viewer(‘cesiumContainer’, {timeline : false, animation : false});
var pinBuilder = new Cesium.PinBuilder();
var bluePin = viewer.entities.add({
description: ‘
This is my pin
It’s color is royal blue’,
position : Cesium.Cartesian3.fromDegrees(-75.170726, 39.9208667),
billboard : {
image : pinBuilder.fromColor(Cesium.Color.ROYALBLUE, 48).toDataURL(),
verticalOrigin : Cesium.VerticalOrigin.BOTTOM
viewer.zoomTo(bluePin);
The name property appears as the InfoBox panel header, and the description property can be seen in the panel body.
Thank you for the reply. The solution seems legitimate but I am afraid that it doesn't work for my use case. My application doesn't have any user interaction and I need to show up some content when the camera zooms to the pin. Do you have any solution to this?
You can select the entity without clicking by setting the viewer.selectedEntity property.
For the example I posted above, add
viewer.selectedEntity = bluePin;
