Polygon with perPositionHeight has missing triangles
I create a small closed model with 6 polygons using primitives
There are missing triangles, I can see inside my model
This should not be happening?
Code example sandcastle
I am trying to find a good way to draw in 3d
OS = windows 10
Cesium is sandcastle latest
Just replace
PolygonGeometry
with:
CoplanarPolygonGeometry
And that should fix it!
I created a little function to render the points to make sure they were all in the right place. Just posting it here in case it’s useful to you or anyone else:
function createPoint(pos) {
var newP = Cesium.Matrix4.multiplyByPoint(mat, Cesium.Cartesian3.fromArray(pos), new Cesium.Cartesian3());
var point = viewer.entities.add({
position : newP,
point : {
color : Cesium.Color.RED,
pixelSize : 5
return point;
I’m guessing you just need to create roof2 to complete this building.
Hi Omar,
Thanks for the reply. I was not aware of the function
`CoplanarPolygonGeometry`
We also finally remembered how we solved this last time, which was to do our own triangulation before creating polygons. This also works for non-planar polygons.
Patrick
