I’m reading in a couple JSON files and constructing a CZML, I cant seem to get the polygons to show on the map at all.
function geoArray (GeometryArray) {
pointList =
for (var l = 0; l < GeometryArray.length; l++){
var geometryArr = GeometryArray[l];
for (var n = 0; n < geometryArr[0].length; n++){
var pointA = {“cartographicDegrees” : Cesium.Cartographic.fromDegrees(geometryArr[0][n][1], geometryArr[0][n][0])};
pointList.push(pointA);
return pointList
var TraffickingCZML = [{
“id” : “document”,
“name” : “CZML Geometries: Country by Trafficking Cases”,
“version” : “1.0”,
clock: {
interval: ‘1990-01-01T00:00:00.000Z/2018-12-13T23:59:59.000Z’,
currentTime: ‘1990-01-01T00:00:00.000Z’,
d3.json(‘static/data/globe.geo.json’).then(function (globe) {
if( globe ) {
d3.json(’/static/data/TraffickingGDPCounts.json’).then(function (trafficking) {
var TrafficArray = trafficking;
var arr = globe.features;
for (var i = 0; i < arr.length; i++){
var obj = arr[i];
for (var n = 0; n < TrafficArray.length; n++){
var traffickObj = TrafficArray[n];
if (traffickObj[‘properties.code’] == obj[‘properties’][‘iso_a2’]) {
if (traffickObj[‘Total’]) {
var geometryPacket ={
“id” : obj[‘properties’][‘postal’],
“name” : obj[‘properties’][‘geounit’],
“availability” : traffickObj[‘Year’] + ‘-01-01T00:00:00.000Z’ + ‘/’ + traffickObj[‘Year’] + ‘-12-31T23:59:59.999Z’,
“vertexPositions” : {“cartographicDegrees” : geoArray(obj[‘geometry’][‘coordinates’])},
“polygon” : {
“show”: true,
“material” : {
“solidColor” : {
“color” : traffickObj[‘properties.color’]
“extrudedHeight” : 100000 * traffickObj[‘Total’],
“perPositionHeight” : true,
“outline” : true,
“outlineColor” : {
“rgba” : [0, 0, 0, 255]
TraffickingCZML.push(geometryPacket);
shouldAnimate : true,
terrainProvider: Cesium.createWorldTerrain(),
var tileset = viewer.scene.primitives.add(
new Cesium.Cesium3DTileset({
url: Cesium.IonResource.fromAssetId(3)
var promise = Cesium.CzmlDataSource.load(TraffickingCZML)
promise.then(function(dataSource) {
geometry Packet looks like this in the console:
- {id: “CO”, name: “Colombia”, availability: “2010-01-01T00:00:00.000Z/2010-12-31T23:59:59.999Z”, vertexPositions: {…}, polygon: {…}}
- availability: “2010-01-01T00:00:00.000Z/2010-12-31T23:59:59.999Z”
- id: “CO”
- name: “Colombia”
- polygon:
- extrudedHeight: 1300000
- material:
- solidColor: {color: “CHARTREUSE”}
- proto: Object
- outline: true
- outlineColor:
- rgba: (4) [0, 0, 0, 255]
- proto: Object
- perPositionHeight: true
- show: true
- proto: Object
- vertexPositions:
- cartographicDegrees: Array(26)
- 0:
- cartographicDegrees: s {longitude: 0.046902920334411694, latitude: -1.3649328324461212, height: 0}
- proto: Object
Needed to break up my json objects because they were too large.
Using Cesium 1.52 in Chrome, Thanks so much for your help!
