I noticed that the behavior of polylines whose endpoint is elevated above ground appears to have been discussed in s community post and that that post referenced this issue. The issue is open, but I thought I’d mention them here in case there’s a quick solution to what I’m seeing now.
When I map polylines in czml that have enpoints or midpoints with a non-zero altitude, their initial point on the ground, demarked with altitude 0 as shown below, doesn’t clamp to the ground. Here’s an example of a polyline definition:
"id":"f2n7wpo",
"name":"n7wpo",
"description":"<H2>n7wpo</H2><table><tr><td>datetime2 = 2025-02-16T02:09:28</td></tr><tr><td>rst = 559</td></tr></table>",
"polyline":{
"positions":{
"cartographicDegrees":[-122.39556128064362,37.79932829961188,-5, -122.77430903389264,42.95907274855483,301000]
"material":{
"solidColor":{
"color":{
"rgba":[0,255,0,255]
"show":[
"interval":"2025-02-16T02:08:28Z/2025-02-16T02:08:46Z",
"boolean":true
"width":5,
"relativeToGround":true
You can see the behavior on this map .
When you zoom in, notice that the polylines that ascend into space are not on the ground.
In this example, the polylines were orignally below ground when specified with a 0 altitude starting point:
Is there a flag to set for polylines that will clamp their origin point to ground level?
In the mean time, I used ChatGPT to develop JavaScript code that provdies altitude adjustment so I can move the lines up or down till they do start on the ground, and then save the updated czml. Here’s a video of the code in action.
Hamilton Carter
