Polyline with Arrow and Dashed materials
I want to draw a polyline and apply both the PolylineArrow and PolylineDashed materials to it, so i end up with a dashed arrow.
var arrowColor = Cesium.Color.fromCssColorString(style.lineColor);
        arrow = new Cesium.PolylineArrowMaterialProperty(arrowColor);
//how can i combine arrow material with dashed material?
var polyline = this._viewer.entities.add({
        polyline : {
          positions : positions,
          width : style.lineWidth,
          material : arrow
I want to draw an arrow with a dashed line.
Cesium 1.35.1 , we may be updating to 1.41 soon
Hi there,
Currently, there is no built in polyline material for both dashes and arrows. You could create your own material using GLSL and fabric, or you could modify the shaders of the built in materials.
If you do create a new material, consider contributing it as a new built-in material so others can use it!
Gabby
