Polylines "flash" when some parameter is changed
I’m drawing some routes on the map as polylines.
I’d like my routes to change their width on the basis of camera height (the farther the camera, the thinner the polyline).
When the width of my routes is updated them “flash”, just like them was destroyed and created from scratch
(I’ve experienced the same problem also changing the polyline material)
Track = viewer.entities.add({
polyline: {
positions: this.cartesianPositions,
clampToGround: false,
width: 6,
show: main.isTrackVisible,
material: this.defaultMaterial,
viewer.camera.changed.addEventListener(() => {
let maxWidth = 6;
let minWidth = 3.5;
let minHeight = 1;
let maxHeight = 6;
let clampedHeight = Math.clamp(height, minHeight, maxHeight);
let widthMult = 1 - Math.inverseLerp(minHeight, maxHeight, clampedHeight);
let width = minWidth + ((maxWidth - minWidth) * widthMult);
Track.polyline.width = width;
I’d like my routes to change their width, and material, on the basis of camera height
1.66
Entities will “flash” like this because they are created asynchronously. If you know your entity is going to change a lot, consider using a CallbackProperty.
Here’s a thread with more detail on this issue: https://groups.google.com/d/msg/cesium-dev/5N1P_qPmbPo/rbnHNKFoAQAJ
Many thanks!
