I drew 3 axes X, Y, Z by using Cesium.Polyline and used cartesian (0, 0, 0) as origin. Each length of axis is 1,000 Km, so they will be expected to be partially above ground.
To distinguish the undergound part and part above ground, I set the depthFailMaterial attributes for polyline (underground parts will be a little bit transparent).
The problem is: I noticed that the juction point of undergound part and part above ground is not fixed at a specific location, it will be moved when I rotate the globe (or tilt the camera).
(the junction point)
Demo link: http://203.66.57.234/axis/
let xAxis = viewer.entities.add({
polyline : {
positions : [new Cesium.Cartesian3(0.000001, 0, 0), new Cesium.Cartesian3(10000000(6371000), 0, 0)],
width : 10,
arcType : Cesium.ArcType.NONE,
material : new Cesium.PolylineArrowMaterialProperty(Cesium.Color.RED),
depthFailMaterial: new Cesium.PolylineArrowMaterialProperty(new Cesium.Color(1.0, 0, 0, 0.2))
let yAxis = viewer.entities.add({
polyline : {
positions : [new Cesium.Cartesian3(0, 0.000001, 0), new Cesium.Cartesian3(0, 10000000, 0)],
width : 10,
material : new Cesium.PolylineArrowMaterialProperty(Cesium.Color.GREEN),
depthFailMaterial: new Cesium.PolylineArrowMaterialProperty(new Cesium.Color(0, 1, 0, 0.2))
let zAxis = viewer.entities.add({
polyline : {
positions : [new Cesium.Cartesian3(0, 0, 0.000001), new Cesium.Cartesian3(0, 0, 10000000)],
width : 10,
material : new Cesium.PolylineArrowMaterialProperty(Cesium.Color.BLUE),
depthFailMaterial: new Cesium.PolylineArrowMaterialProperty(new Cesium.Color(0, 0, 1, 0.2))
I want to draw XYZ axes to indicate 3D models’ origin.
Cesium v1.58 on Windows Chrome browser (76.0.3809.100)
