Hi everybody,
Playing around with Cesium the first time because the Google Earth Plugin will not be available anymore next month as you all probably know.
The first thing I would like to do is show some pins(markers) on a cesium map with terrain.
When the cesium map is first loaded then the pins are shown on the correct position but as soon as I start turning the globe with ctrl left mouse button the pins also move.
When zoomed in to the pin and you move the globe to left, right up or down the pin also moves to a different position.
With this the layers (pins) loose there position and you cannot display layers correctly when using terrain.
Here is an example of what I mean. Zoom in to blue pin and after that use you ctrl left mouse button to show the terrain. When you turn the globe you will see that the content also moves which in my opinion should not move.
http://17.mcyclingthealps.appspot.com/cesium2/Apps/Sandcastle/gallery/routes.html
Is there a way to fix the position of pins?
I have looked at powdertracks and there the pins are fixed. You can turn the globe around and all the pins stay on there postition.
Thanks for any feedback.
Dennis
