I'm trying to create a Polymer 2.0 web component that uses Cesium JS. I have included the Cesium files, created a <div> element in the Polymer template with an id 'globeContainer', and then attempted to initialize it with `new Cesium.Viewer('globeContainer'). However, the console reports the error: "Uncaught TypeError: Cannot read property 'appendChild' of null". I noticed this also happens if I run the 'HelloWorld' demo and provide an incorrect id name to the Viewer() constructor (i.e. an id for an element not in the DOM).
DIRECTORY STRUCTURE: ----------------------------------------------------------
app/src
>_ cesium-globe
>_ Cesium-1.43/
>_ cesium-globe.html
CODE: -------------------------------------------------------------------------
<!-- Import the base Polymer element dependencies -->
<link rel="import" href="/bower_components/polymer/polymer-element.html">
<!-- Import other dependencies -->
<dom-module id="cesium-globe">
<template>
<style>
@import url([[importPath]]Cesium-1.43/Build/Cesium/Widgets/widgets.css);
:host{
#globeContainer {
width: 100%;
height: 100%;
margin: 0;
padding: 0;
overflow: hidden;
</style>
<div id="globeContainer"></div>
<!-- Import cesium script -->
<script src="[[importPath]]Cesium-1.43/Build/Cesium/Cesium.js"></script>
</template>
<script>
class CesiumGlobe extends Polymer.Element {
static get is() { return 'cesium-globe'; }
static get properties(){ ... }
ready() {
super.ready();
var viewer = new Cesium.Viewer('globeContainer');
window.customElements.define(CesiumGlobe.is, CesiumGlobe);
</script>
</dom-module>
ERROR: -----------------------------------------------------------------------
at new $ (Cesium.js:558)
at HTMLElement.ready (cesium-globe.html:44)
at HTMLElement._enableProperties (properties-changed.html:321)
at HTMLElement.connectedCallback (properties-mixin.html:208)
at HTMLElement.connectedCallback (element-mixin.html:532)
at HTMLElement._attachDom (element-mixin.html:588)
at HTMLElement._readyClients (element-mixin.html:561)
at HTMLElement._flushClients (property-effects.html:1565)
at HTMLElement._propertiesChanged (property-effects.html:1699)
at HTMLElement._flushProperties (properties-changed.html:338)
I need to create a plug-able web component using Polymer that provides a 3D globe view that we can add data to. Cesium provides a really slick interface for this, so I would like to use it. However, it doesn't seem to play nice with the shadow DOM Polymer uses.
Cesium 1.43
Kubuntu 17.10
Chrome
