Hi all,
I’m encountering an issue when trying to build off of the QuickStart guide using the CDN import method. I used the code in the CDN import method from the QuickStart guide (link), and then expanded it by working my way through some of the entity creation demos. However, I cannot get the entity description to render in the InfoBox when using the CDN import method.
It works just fine in Sandcastle (here’s a link to one I made).
I have some suspicion as to why this is occurring. When running the code from the Cesium QuickStart guide, a console error is raised:
caught TypeError: Cannot read properties of null (reading 'createElement')
at HTMLIFrameElement.<anonymous> (Cesium.js:56:182157)
(anonymous) @ Cesium.js:56
load
This error does not prevent the globe for rendering, and all the demos and examples can be done just fine despite this error. However, I suspect that it may be causing my issue with the description not rendering. Here’s a small code snippet from the offending section of code in cesium.js:
o.addEventListener("load", (function() {
const e = o.contentDocument
, n = e.createElement("link"); // This is the line that throws the error
n.href = buildModuleUrl("Widgets/InfoBox/InfoBoxDescription.css"), // Therefore this wont run
n.rel = "stylesheet",
n.type = "text/css";
const i = e.createElement("div");
i.className = "cesium-infoBox-description",
The error is thrown right before some configuration of the InfoBoxDescription occurs, and therefore it appears to me that this is causing an issue with the rendering of the InfoBox description. Please note that I am new to Cesium, and I could be way off base here. Would anyone be able to help me devise a solution to this problem? Or a work-around? I’m working on a project that would require the CDN method and would also greatly benefit from using the InfoBox description.
Here’s the HTML file I was using:
<html lang="en">
<head>
<meta charset="utf-8">
<!-- Include the CesiumJS JavaScript and CSS files -->
<script src="https://cesium.com/downloads/cesiumjs/releases/1.105.1/Build/Cesium/Cesium.js"></script>
<link href="https://cesium.com/downloads/cesiumjs/releases/1.105.1/Build/Cesium/Widgets/widgets.css" rel="stylesheet">
</head>
<body>
<div id="cesiumContainer"></div>
<script>
// Access Token
Cesium.Ion.defaultAccessToken = 'XXXXXXXXXXXXXXXXXXXXx'
// Initialize the Cesium Viewer in the HTML element with the `cesiumContainer` ID.
const viewer = new Cesium.Viewer('cesiumContainer');
// Add scene entities
const scene_objects = [];
var entity = ''
var point1 = viewer.entities.add({
name : "Point 1", position : Cesium.Cartesian3.fromDegrees(-75.000000000, 45.000000000, 0.000000000),
point : {pixelSize : 10, color : Cesium.Color.GREEN}
point1.description = "<p>This is a point</p>"
scene_objects.push(point1)
// Zoom to last object
viewer.zoomTo(scene_objects[scene_objects.length-1]);
</script>
</body>
</html>
Note that this problem was identified in an earlier post, but the issue remained unsolved.
Entity description not displaying - CesiumJS - Cesium Community
Version: 1.105.1
Attempted on Chrome and Edge
