We’re having issues where 3D tiles that are on top of the globe are being clipped by it. It looks like it could be a depth test issue. If the camera is viewing the tiles from a certain distance then the tiles appear clipped. Attached a screenshot of what I mean. We’ve seen this on 3D tiles that are located in the USA. Tiles located in Australia seem fine.
We’re using Cesium 1.57 on Mac and chrome. Although it looks like this problem exists on earlier versions of cesium too.
And let me know if that fixes the issue? if not, are you able to share your tileset in a Sandcastle for me to try it? If you can’t share it publicly feel free to email me at omar@cesium.com
Thanks Omar, I’ve tried what you suggested and it does seem to fix the clipping issue. However the ground level of our terrain is slightly above the ground level of the 3D tiles, so it doesnt look right. Ideally we’d like to keep this property turned off.
I believe you already have our tileset for New York City. From this PR: https://github.com/AnalyticalGraphicsInc/cesium/pull/7774 it says you’ve done testing on Nearmap NYC. These tiles have the same issue when the camera is at grazing angles such as the screenshot I sent you.
We’ve done some more investigation and found that the problem is occurring in places where the 3D tiles are below the ellipsoid (without any terrain provider being used).
We are using the Cesium ION provider and the terrain geometry matches closely to our 3D tiles. If we disable the terrain provider then weve found that affected tilesets are always below the ellipsoid.
Thanks for posting this additional information Adam. So just to confirm, is the terrain you’re using itself below the ellipsoid in this location?
I was going to suggest you can use the ion tileset location adjust tool to lift the tileset’s height up, but it sounds like tileset being below the ellipsoid is correct here?
I think I recently ran into this same issue on a different tileset. I believe the issue here is that the depth plane (which Cesium uses to prevent things on the other side of the globe from rendering when depthTestAgainstTerrain if off) is rendering slightly above the ellipsoid at certain angles. This can be confirmed either way by commenting out the two occurrences of depthPlane.execute in Scene.js:
