No possiblity to dynamically and smoothly change the colors of the entities. In the case that I use to illustrate the problem, a series of yellow circles is created, and it is required that the transparency of the circles should gradually change over time. It can be implemented by means of direct access to the material property of the ellipse entities, but this way doesn’t work well since it interferes with the animation of other entities and due to it makes the circles blink. I tried to implement the updates via the CallbackProperty, but I didn’t manage to find a solution. Could you please help to solve the problem?
//------------------------------- START VIEWER ---------------------------------
navigationHelpButton: false,
animation: false,
timeline: false,
homeButton: false,
scene3DOnly : true
//----------------------------- NAVIGATE TO PLACE ------------------------------
var lon = 40, lat = 60;
viewer.camera.flyTo({destination: Cesium.Cartesian3.fromDegrees(lon, lat, 1000), duration: 1});
//--------------------- MANAGE THE ARRAY OF YELLOW CIRCLES ---------------------
var yellowCircles = {}; // Define the array of yellow circles
// Another yellow circle appears in a random place every 5 seconds.
// The lifetime of each circle is 30 seconds
setInterval(function(){
var yc = new createYellowCircle(); // Create a new circle
yellowCircles[yc.id] = yc; // Copy the circle to the array
}, 5000);
// This procedure inspects all circles 4 times per second
// to change the alphas in their material parameters and to remove expired circles
for(var c in yellowCircles){ // Look through all yellow circles
var c_entity = viewer.entities.getById©; // Get an entity of yellow circle
var now = new Date().getTime() / 1000;
var expiration = (now - yellowCircles[c].created) / yellowCircles[c].lifetime; // Check if the circle lifetime is expired or not
if(expiration < 1){ // If the circle is not expired
var alpha = 1 - expiration; // Calculate new alpha (it should decrease from 1 to 0 over time)
yellowCircles[c].color = Cesium.Color.YELLOW.withAlpha(alpha); // Use alpha to update property color of the yellow circle object
/* The commented below operation allows to update the colors, but this solution doesn’t work well, since
it eventually starts oppressing the animation of other objects,
it makes circles blinking
c_entity.ellipse.material = new Cesium.ColorMaterialProperty(yellowCircles[c].color);
} else{ // If the circle is expired
viewer.entities.remove(c_entity); // Remove entity frome viewer
delete yellowCircles[c]; // Remove the correspondent object instance from the array of yellow circles
}, 250);
// This is an object constructor that creates a new yellow circle
createYellowCircle = function(){
this.created = new Date().getTime() / 1000; // In seconds
this.lifetime = 30; // In seconds
this.color = Cesium.Color.YELLOW.withAlpha(1); // Start from alpha = 1 (opaque circle)
var longitude = lon + 200 * (Math.random() - 0.5) * 1e-5; // Generate the coordinates randomly
var latitude = lat + 200 * (Math.random() - 0.5) * 1e-5;
this.id = Math.floor(Math.random() * 1e12).toString(); // Generate the unique id of the entity
this.entity = {
position : Cesium.Cartesian3.fromDegrees(longitude, latitude),
The parameter upadate by means of CallbackProperty works fine for position updates,
but it neither allows to update entire ellipse nor
separately its material property
ellipse : new Cesium.CallbackProperty(function(){
return {
semiMinorAxis : 25,
semiMajorAxis : 25,
material : new Cesium.ColorMaterialProperty(this.color)
}, false)
ellipse : {
semiMinorAxis : 25,
semiMajorAxis : 25,
material : new Cesium.ColorMaterialProperty(this.color) // !!! No possibility to dynamically update alpha
viewer.entities.add(this.entity);
viewer.camera.flyTo({destination: Cesium.Cartesian3.fromDegrees(longitude, latitude, 500), duration: 2.5}); // Find the new circle on the map
Object color updates are commonly used in graphical applications.
Cesium 1.38, Windows, Chrome
