I create a primitive that is composed of tens of thousands of Geometry Instances. Removing this primitive using the "remove()" function seems to take significantly longer on Linux compared to Windows.
On Windows, using Chrome browser: ~12 ms
On Linux, using Chromium browser: ~4500 ms
Are there any known performance issues with primitives.remove() on Linux? Does anyone have a workaround (i.e another way to get rid of primitives that might be quicker)?
At the bottom is a link to a sandcastle example which constructs a massive random shape composed of tens of thousands of triangles. It places these triangles into a Primitive.
I have added a callback to the example which removes the primitive when you click anywhere on the map, and prints the amount of time taken by "remove()" to the console.
Try the below example, click anywhere on the map to see the primitive get removed. Then look at the console to see how much time it took (try it on Linux and Windows).
I am using lots of triangle geometry instances to create colored surface plots of different shapes. The below example shows a nonsensical shape with garbage data, but I use this same approach for more complex shapes, which results in greater performance disparities.
Reproduced the issue with Cesium 1.50, on Windows w/ Chrome, and Linux w/ Chromium.
LINK TO SANDCASTLE EXAMPLE:
