Primitive added via scene.primitives.add not displaying
I’m having trouble getting a line to display in the viewer when I add it via a scene.primitive.
What am I missing?
Initializing a polyline in the add function of PolylineCollection is a bit different than what you have. You don’t need the polyline key in the map. Something like this should work: Sandcastle.
You can see the possible options for Polyline here: Documentation.
Ah thank you! That worked. How do I ensure that line stays clamped to the ground?
Glad to help!
There isn’t a clampToGround tag for Polyline. I would go with Entity in this case.
