Problem of visualizing geometry
Hi all,
I’m encountering an issue when visualizing pipes.
The pipes is displayed correctly in this view
However, in other views where the angle between the pipe and view direction is less than 80 degrees, there are many spots around the pipe.
Note: I am using custom shader.
Thanks for your concerns
Hi @Hung,
Thanks for your post and being a part of the Cesium community.
Are you able to provide a sandcastle example https://sandcastle.cesium.com/ that reproduces the problem you are seeing? This will make it easier for us to evaluate and address the issue you are seeing and hopefully quickly drill down on the root cause.
Please let us know if we can help with getting the sandcastle example together.
Luke
Hi, @Luke_McKinstry
I discovered that the issue was related to my specific computer configuration. When I ran the project on a different machine, the bug no longer appeared.
Hung
