Problem serving terrain files in IIS
I have success with my own generated height map and orthophoto to view in Cesium.
The development machine was using Apache as the web server.
To serve out the *.terrain files, this was added to .htaccess file.
<filesMatch “(.*).terrain$”>
ForceType application/octet-stream
Header set Content-Disposition attachment
Header set Content-Encoding: gzip
However for deployment, the client’s server requires using IIS as the web server. The error that appear are
An error occurred in “E”: Failed to obtain terrain tile X: 0 Y: 0 Level: 0.
An error occurred in “E”: Failed to obtain terrain tile X: 1 Y: 0 Level: 0.
I have tried the following:
  1. add “” to web.config file
  2. use " " to web.config as specified in cesium download.
  3. point directly to “http://myurl/elevation/0/0/0.terrain” and “http://myurl/elevation/0/1/0.terrain”. The 0.terrain file will automatically be downloaded to the disk.
I believe it an issue of web.config to specify what to do with the terrain files to be similiar to .htaccess.
Any pointers is appreciated.
Hi there,
Serving terrain requires a specific configuration for handling tile requests.
I would recommend creating a Cesium ion account and uploading, processing, and serving your data there.
Optionally, there is the STK Terrain Server or other solutions for serving terrain.
Gabby
Change IIS configuration , adding “content-encoding” “gzip” in the header of subfolder (0-19) of terrain directory.
Not in parent directory, because file like “layer.json” are not zipped.
Web.config in the foleter terrain\0 terrain\1 etc… is
<?xml version="1.0" encoding="UTF-8"?>
