I am following the guidelines at : cesium/Documentation/OfflineGuide at main · CesiumGS/cesium (github.com)
I have an http server running and it can serve up .terrain files with the appropriate mime encoding of application/octet-stream. My layer.json is correct.
I am getting the error:
An error occurred in “gh”: Failed to obtain terrain tile X: 0 Y: 0 Level: 0. Error message: “RangeError: Invalid typed array length: 10729171605”
Cesium.js:9418 An error occurred in “gh”: Failed to obtain terrain tile X: 1 Y: 0 Level: 0. Error message: “RangeError: Invalid typed array length: 855693507”
What could be wrong?
Please advise.
Thanks much,
-Timothy
Hello, Im not sure I understand.
Do I need to gzip the files or specify gzip in the server config?
OK, the http-server is not real configurable, so to get the proper gzip content-encoding there are a couple things to do.
NOTE: .terrain files are gzipped, so for anyone interested here is a workaround:
- rename all .terrain files on the server to .terrain.gz using your favorite cmd/bash rename script
- set a custom.types file to have the following
application/vnd.quantized-mesh;extensions=octvertexnormals terrain
- run the http-server with the -g --mimetype custom.types
- you are up an running.
unzipping the terrain files is a definite no-go, so the above is what worked for me.
Thanks much,
-Timothy
