Hey,
I’ve been trying to start working with GroundPrimitives, and this is what I see when I try to work with the example in Sandcastle.
Unless it is a bug, could it be a gpu issue? I am using Radeon HD 6450 with 512 memory, on windows 7. There are no errors in the console or WebGL reports
Cesium.GroundPrimitive.isSupported(scene)
returns true
This is my chrome://gpu in case that helps
Graphics Feature Status
- Canvas: Hardware accelerated
- Flash: Hardware accelerated
- Flash Stage3D: Hardware accelerated
- Flash Stage3D Baseline profile: Hardware accelerated
- Compositing: Hardware accelerated
- Multiple Raster Threads: Enabled
- Rasterization: Hardware accelerated
- Video Decode: Hardware accelerated
- Video Encode: Hardware accelerated
- WebGL: Hardware accelerated
Driver Bug Workarounds
- clear_uniforms_before_first_program_use
- disable_d3d11
- exit_on_context_lost
- scalarize_vec_and_mat_constructor_args
- texsubimage_faster_than_teximage
Problems Detected
- Some drivers are unable to reset the D3D device in the GPU process sandbox
Applied Workarounds: exit_on_context_lost - TexSubImage is faster for full uploads on ANGLE
Applied Workarounds: texsubimage_faster_than_teximage - Clear uniforms before first program use on all platforms: 124764, 349137
Applied Workarounds: clear_uniforms_before_first_program_use - Always rewrite vec/mat constructors to be consistent: 398694
Applied Workarounds: scalarize_vec_and_mat_constructor_args - Disable Direct3D11 on systems with AMD switchable graphics: 451420
Applied Workarounds: disable_d3d11
