I have a fairly complicated Cesium based site that has been mixing primitives and entities without issues for many iterations. The original entities version launch message on this forum indicated that primitives and entities can co-exist safely.
Last night I added a new entity of type 'point' (using the Sandcastle Showcase 'Points' code as an example).
After I call entities.remove to remove my point I also call primitives.removeAll() to remove my primitive types from the scene. I then add another entity of type point. As soon as I add this point entity I get:
DeveloperError: This object was destroyed, i.e., destroy() was called.
Error
at new t (http://localhost:81/Build/Cesium/Cesium.js:424:6660)
at A.o (http://localhost:81/Build/Cesium/Cesium.js:428:29924)
at h.update (http://localhost:81/Build/Cesium/Cesium.js:454:5173)
at x.update (http://localhost:81/Build/Cesium/Cesium.js:455:15704)
at Y._onTick (http://localhost:81/Build/Cesium/Cesium.js:477:3362)
at i.raiseEvent (http://localhost:81/Build/Cesium/Cesium.js:424:23947)
at l.tick (http://localhost:81/Build/Cesium/Cesium.js:431:31042)
at A.render (http://localhost:81/Build/Cesium/Cesium.js:474:13132)
at t (http://localhost:81/Build/Cesium/Cesium.js:473:31914)
This happens on creating a new entity and adding to the scene.
I've created a minimal script to repro the problem. Clicking the folllowing button sequence : Entity,Clear,Entity I get the rendering has stopped message.
I'm using Cesium 1.18. Can anyone help me understand the cause of the problem please?
<script id="cesium_sandcastle_script">
var _viewer;
var _entity;
function startup(Cesium) {
"use strict";
_entity = null;
_viewer = new Cesium.Viewer('cesiumContainer',
animation: false,
geocoder: false,
timeline: false,
orderIndependentTranslucency: false
Sandcastle.addToolbarButton("Entity", onEntityClick);
Sandcastle.addToolbarButton("Clear", onClearClick);
Sandcastle.finishedLoading();
if (typeof Cesium !== "undefined") {
startup(Cesium);
} else if (typeof require === "function") {
require(["Cesium"], startup);
function onEntityClick() {
clearEntity();
_entity = _viewer.entities.add({
position: Cesium.Cartesian3.fromDegrees(-122.332769, 47.605560),
point: {
pixelSize: 15,
color: Cesium.Color.LIME
function onClearClick() {
clearEntity();
_viewer.scene.primitives.removeAll();
function clearEntity() {
if( _entity != null) {
_viewer.entities.remove( _entity);
_entity = null;
</script>
