Now I want to know the syntax of such function like this:
Cesium.CzmlDataSource.processMaterialPacketData(object, propertyName, packetData, interval, sourceUri, entityCollection)
Cesium.CzmlDataSource.processPacketData(type, object, propertyName, packetData, interval, sourceUri, entityCollection)
I want to know how to call this function.Can I write like this directly, if I want to update the material.solidColor of the first packet?
Or these functions just mean to make some custom properties, not to update the packet? I am very confused.
Thanks if you can give an answer.
var czml = [
“id” : “document”,
“name” : “CZML Geometries: Polygon”,
“version” : “1.0”
“id” : “redPolygon”,
“name” : “Red polygon on surface”,
“polygon” : {
“positions” : {
“cartographicDegrees” : [
-115.0, 37.0, 0,
-115.0, 32.0, 0,
-107.0, 33.0, 0,
-102.0, 31.0, 0,
-102.0, 35.0, 0
“material” : {
“solidColor” : {
“color” : {
“rgba” : [255, 0, 0, 255]
“id” : “greenPolygon”,
“name” : “Green extruded polygon”,
“polygon” : {
“positions” : {
-108.0, 42.0, 0,
-100.0, 42.0, 0,
-104.0, 40.0, 0
“material” : {
“solidColor” : {
“color” : {
“rgba” : [0, 255, 0, 255]
“extrudedHeight” : 500000.0
“id” : “orangePolygon”,
“name” : “Orange polygon with per-position heights and outline”,
“polygon” : {
“positions” : {
-108.0, 25.0, 100000,
-100.0, 25.0, 100000,
-100.0, 30.0, 100000,
-108.0, 30.0, 300000
“material” : {
“solidColor” : {
“color” : {
“rgba” : [255, 100, 0, 100]
“extrudedHeight” : 0,
“perPositionHeight” : true,
“outline” : true,
“outlineColor” : {
“rgba” : [0, 0, 0, 255]
var czmlDataSource = new Cesium.CzmlDataSource();
czmlDataSource.load(czml);
viewer.dataSources.add(czmlDataSource);
var object = czmlDataSource.entities.values[0];
var packetData=object.color;
var propertyName=‘color’;
var interval=object.interval;
var entityCollection=czmlDataSource.entities;
Cesium.CzmlDataSource.processMaterialPacketData(object, propertyName, packetData, interval,undefined, entityCollection)
{ //I want to update the firdt packet’s solidcolor into BROWN
object.solidColor=Cesium.Color.BLUE ;
viewer.zoomTo(czmlDataSource);
